How do I solve this inverse kinematics issue
ahsan_ahmedahsan_ahmed Member Posts: 2 EDU
I have 2 rotatable arms, and when I try to mate them with a revolute, onshape can't solve the assembly and caues other mates to break:
Once mated:
Is there a way I can get the assembly to solve with inverse kinematics?
https://cad.onshape.com/documents/044489cf90bf8bba13046e46/w/f005f843b6ad9e5f2bf02ea4/e/e853c1892c9a9c5eecee8049
  • eric_pestyeric_pesty Member Posts: 2,379 PRO
    I'm guessing there the links already have mates that constrain them on the Z direction and there is mis-match somewhere (could even just be a rounding error in the math).
    Change that revolute mate to a cylindrical mate to avoid this.
  • EvanReeseEvanReese Member, Mentor Posts: 2,590 PRO
    Agree that a cylindrical mate is the way to go. Otherwise you have two different mates telling that part exactly where it should go, and even if they "say the same thing" software tolerance limits can cause failures. With cylindrical, only 1 mate is defining the z position of the link.
