  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,509 PRO
    Your path needs to be a single curve (you can create a fit spline from you sketch geometry) and then you can use a tangent mate between a vertex and the path.
    That won't lock rotation so you will need more constraints for that (like multiple vertices following the path or an external "parallel", or you instead of just a curve you cand use a surface and have edge be tangent instead to it instead of just a vertex.
  • vanowmvanowm Member Posts: 117 ✭✭
    edited June 2025
    Thank you!
    I couldn't make spline in sketch precise enough as the 2 lines and an arc, so I used routing curve tool, which made close-enough spline curve and then created surface from it.
    It works great:
    Assembly: follow curve v2
