Detecting used mate connectors?
wei_che_lin
Member Posts: 2 ✭
I am hoping to develop a feature that will scale a model without scaling its used mate connectors. This will allow me to preserve the size of a joint (e.g. a screw hole) while scaling the rest of the model. Is there a way to detect used mate connectors?
Not an expert at all…
But my first thought was that MCs are used for so many things it would likely be hard to keep track of it that way… I'm not sure if there's any way to find "dependencies" in the feature tree through FS.
However if you are talking about hole features (i.e. created with the hole tool), they should have a "tag" that you should be able to use to identify them.
