How to make a "shadow" behind a structure?
martin_olesen
Member Posts: 24 ✭✭
Hello forum
I have made a "lamp" that cast its light on a surface from an angle, and in the "light" path the there is a round pole tube.
I would like to have a a shadow all behind the round pole tube where there are no "light", due to the pole is shadowing from the light source.
Is it possible?
Here is the link to the small project.
https://cad.onshape.com/documents/9315a341bdf83e14c1f23a37/w/3281cb185054b121dbd5969d/e/ceae54dc8166e0204a3f96bd
eric_pesty
Member, pcbaevp Posts: 2,605 PRO
Like this?
I used an in-context edit and the "intersect" option to extrude the area behind the pole.
https://cad.onshape.com/documents/197b95019927043b2ef96960/w/1714cf856381f7b12f0b2ffa/e/ca6468bd1038677af6a45b14?renderMode=0&tangentEdgeStyle=1&uiState=685ae7bd1e4d24445ec712491
Like this?
Very interresting Eric, thank you i will try to see how you did it, thank you.
