How to make a "shadow" behind a structure?
martin_olesenmartin_olesen Member Posts: 24 ✭✭
Hello forum
I have made a "lamp" that cast its light on a surface from an angle, and in the "light" path the there is a round pole tube.
I would like to have a a shadow all behind the round pole tube where there are no "light", due to the pole is shadowing from the light source.
Is it possible?
Here is the link to the small project.
https://cad.onshape.com/documents/9315a341bdf83e14c1f23a37/w/3281cb185054b121dbd5969d/e/ceae54dc8166e0204a3f96bd
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,605 PRO
    Like this?
    I used an in-context edit and the "intersect" option to extrude the area behind the pole.
    https://cad.onshape.com/documents/197b95019927043b2ef96960/w/1714cf856381f7b12f0b2ffa/e/ca6468bd1038677af6a45b14?renderMode=0&tangentEdgeStyle=1&uiState=685ae7bd1e4d24445ec71249
    Like this?
  • martin_olesenmartin_olesen Member Posts: 24 ✭✭
    Very interresting Eric, thank you i will try to see how you did it, thank you.
