Fractions of decimal mesurements
daniel_bevilledaniel_beville Member Posts: 2
Hi, how do I get fractions of a mm.?
When I try it changes to the closest mm.
ie 10.5mm changes to 11mm
  • martin_kopplowmartin_kopplow Member Posts: 837 PRO
    You have probably set the unit precision to no decimals. Set it to 0,123 for workspace and 0,12 for drawings and you should be fine:
