Are there better ways to do these configurations?
joshtargojoshtargo Member Posts: 454 EDU
I made a configurable #25 chain sprocket, but then also made a chain that wraps around it so I can check for clearance.
If the sprocket has an odd number of teeth, it uses a half-link. If it's even, it doesn't need the half link, but the only way I figured to automatically hide the half link using IF logic, was to extrude something either 0" or extrude normally. if it extrudes 0", the half link breaks and simply doesn't show up. But I don't like seeing red!
Is there a better way to prevent a part in the tree from being shown or created using an odd-even check on the user input variable for sprocket teeth?
https://cad.onshape.com/documents/e72b6c7b258f55661cf2d0ca/w/64769064665850fe560aa3e3/e/f190f9139c3268a01eadb0f6
