How do I dimension an image with different aspect ratio
tobias_weiss989tobias_weiss989 Member Posts: 4
I am trying to scale this image to the correct dimension but the sketch could not be solved. What am I doing wrong?
Is it not possible for Onshape to change the image dimensions?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 841 PRO
    Pretty sure you cannot change the aspect ratio of an image in a sketch. You'll have to edit the image outside of Onshape and bring it in.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,469 PRO
    Another option is to use the "image" Featurescript (instead of a sketch image):
    https://cad.onshape.com/documents/f7a45d78c374497d37c1d2cb/v/e55cc4b62eaac7ef75039ab2/e/af89d519b2985176cfd7eb55
  • tobias_weiss989tobias_weiss989 Member Posts: 4
    Thank you. Would be a really nice feature to have
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,033 PRO
    The problem is the image itself. It has "marketing dimensions", not true dimensions on it. It's not even clear what the dimensions are pointing to.
    You'll have to pick either the height or the width, and dimension that side only. If you dimension both, it will be over-constrained.
