I designed an ITX board mounting hole stencil but... printer problems
MannyFMannyF Member Posts: 21 ✭✭
I printed the stencil at 100% scaling, measured actual dimensions on the printed drawing and applied a correction factor in my printer settings. The problem is the printer seems to be squashing the drawing in one axis more than the other, but my printer only provides a single scale field that is applied to both axes. Is there any easy way to apply a correction factor to each axis separately in OnShape? If this is not possible, I'll have to hack the drawing so the printed drawing comes out dimensionally accurate.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 744 ✭✭✭
    Hey Manny. So, your printer printed the stencil to a size that was different than what presumably was in the file you sent to it and either the X or Y dimensions were uniformly wrong but not both? You want to compensate for the error in Onshape, correct? Is this a 2D paper stencil or a 3D stencil? - Scotty
