Holes and Constraints
william_turleywilliam_turley Member Posts: 8
https://cad.onshape.com/documents/66ec667b69402e78d72be64c/w/5c527241399c46d4f49d969c/e/82cc5fb6ade076d13d29d41b
Hello,
I attempted to use the Circular Pattern tool to make my four holes in place of where had used the Center Point Circle tool and now I'm told my plane is undefined even though I can't find any blue markings. Is there a way I can extrude each circles face hole on both a positive and negative z axis (all the way through) in addition to avoiding the constraint issue?
  • glen_dewsburyglen_dewsbury Member Posts: 1,091 PRO
    edited July 2 Answer ✓
    Use an alternate plane to start holes.
    https://cad.onshape.com/documents/2f96dbdee80691df06a7f1ab/w/4c3397d0a9b350e7b55c4fc7/e/b9ff79202843b07bc5c397d4
  • william_turleywilliam_turley Member Posts: 8
    Thank you!
