Why are the legs not listed as part 2?
ProApeProApe Member Posts: 198 ✭✭
edited July 2 in Using Onshape
Hello,
I want to construct a small table with 2 tops, I first created the top plate (part 1), then a leg as New, so part 2, but in the list of parts there is only part 1.
I have mirrored the leg once and want to mirror the 2 legs again, but I can't select them. Why?
I know it's probably not the best way of construction, without Assembly, but it should still work.
Kind regards
ProApe
https://cad.onshape.com/documents/82a6fb94289d94f9ada4486a/w/865cc4617663278b23ff0d3b/e/2ccde6e97d707fa12b36c8e2?renderMode=0&uiState=68659d3ee4c0e65991149472
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,467 PRO
    The mirror feature is set to "add" so it merges the legs with the table top.
    Set it to "new" and will leave the legs as separate parts
  • ProApeProApe Member Posts: 198 ✭✭
    Hello,
    Thank you!
    That is so logical!
    I hadn't seen that, as with the extrude function, you can/must also choose between New and Add for the mirror function.
    Kind regards
    ProApe
