Making a part follow a 2D sketch
Aly_kAly_k Member Posts: 17
I am not sure if this will make much sense. I want to make my cable trays follow a 2D sketch, but I am not sure if that is possible, please let me know.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 744 ✭✭✭
    Please post a link to your document so we can see what you have. - Scotty
  • MichaelPascoeMichaelPascoe Member Posts: 2,774 PRO
    edited July 2025
    Place your sketch and parts within an assembly, you can use the Tangent mate paired with some other mates to have objects follow a path. The tangent mate doesn't support animations at this time, so if you want your part to be animated, you will have to have a guide part that pushes your trays along the path.
  • Aly_kAly_k Member Posts: 17
    I don't have a link right now to show you I just would like to know if it is possible to make a part (derived) follow a 2D sketch
  • MDesignMDesign Member Posts: 1,292 PRO
    Could you possibly looking for the sweep tool? Hard to say without a visual what your asking for.
    So, I tried the tangent mate and it's not exactly doing what I want it to do my cable tray placements are all 90-degree bends and the tangent mate doesn't allow you to rotate your part is there any other way? I want to be able to manipulate my part just telling it follow this sketch and then place that into an assembly.
    Sounds possible, but will need a link to the document to provide more specific help. Ensure you turn on link sharing and enable copy permissions.
