Question: How to use PersistentCoordSystem?
antlu65antlu65 Member Posts: 61 EDU
edited July 2025 in FeatureScript
Looking for some clarification on how to use the PersistentCoordSystem type to track transformations applied to an entity.
I've set up a document with a minimal example here to illustrate my confusion.
In the document, I have created a new PersistentCoordSystem and assign it to a body entity by setting an attribute on the entity.
I then apply a transform to the body entity.
Now, when I retrieve the PersistentCoordSystem from the attribute attached the entity, the value of the PersistentCoordSystem does not appear to be updated or reflect the transform applied to the entity. If anyone could, please point me in the right direction.
(Documentation for PersistentCoordSystem)
  • jnewthjnewth Member, OS Professional Posts: 113 PRO
    You're working against a few challenges here:
    1. The persistent coord system stuff is not well-documented.
    2. FS type system is weird.
    3. Type system fails in weird ways when used in conjunction with setAttribute. I filed a bug on this a while back so maybe @_anton can add some detail / correct my ignorance.
    Here's a few things I did to your example:
    1. Attach the persistentCoordSys to a face, not a body.
    2. Wrap your id with toString(id + "whatever"); the persistent cs stuff takes a string not an id. This is not consistent with most of the std library but that's how it is.
    3. When recovering the coordinate system at the end, you have to make up for the attribute system stripping your type tags. A coordinate system is a map with keys "origin", "xAxis", and "zAxis". The origin is a point in real space, so it has units. So it's a Vector of ValueWithUnits. The axes are just directions, so they are just Vectors of numbers. When the attribute system returns it to you, the origin, xAxis, and zAxis are returned as arrays - not at all what you want. So you have to recreate the coordinate system by reapplying type tags.
    This makes it work:
    Check it out: https://cad.onshape.com/documents/9f0d51b5b054698f3b0dcec2/w/08edea7dd826af4c3dceff92/e/aea4ec9ab6007589bef2a9f4
  • antlu65antlu65 Member Posts: 61 EDU
    Perfect, exactly what I was looking for, thank you!
  • _anton_anton Member, Onshape Employees Posts: 528 image
    @jnewth While this isn't my area of expertise, I do believe the weirdness in question was fixed a while ago.
