How to revert to a previous version?
I have a document, and a change to the latest version is preventing the document from loading (30-40 minutes, then times out). The last change in the current version was to a length variable from 2in to 1.5in. I can load the previous version, but it's read-only. I am using the free version. I would like to delete the last version created, and go back to the one before.
You can right click on the version and click branch to create a workspace. or click on a historical step and click restore to main at that top of the drawing area
Can he do that when the document isn't loading? I guess the history strip won't be available until it's loaded …
Yes, it can be done from the list view that shows all the documents. Versions and History, and their related abilities, are available there, without the document being open.
Ah, you're right. I forgot about that one.
