How to change which side partial fillet offset offsets from?
Hi, I want to make a partial fillet but when I select offset it chooses the wrong side to offset from and adding a second bound makes it unable to regenerate. Other edges with the same dimensions worked fine since it selected the other side to start the offset from. Is there a way to to manually select which side the offset should be from?
Thanks!
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 371 image
    I think an easier way is to use an "Entity" as the Partial fillet end type. This entity can be a plane or Mate connector or others. In the case below I created a Mate connector offset from the end I wanted to measure from:
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    edited July 2025
    Hi, click that arrow
  • algot_björklundalgot_björklund Member Posts: 4
    Thanks for answering, however that does not solve my problem. That arrow changes which side of the offset the fillet is on, what I want to change is which side the offset is calculated from.
    Image 1 shows the current situation, image 2 shows what the arrows do and image 3 shows what I want.
    Screenshot 2025-07-06 at 14.19.07.jpeg Screenshot 2025-07-06 at 14.19.15.jpeg Screenshot 2025-07-06 at 14.19.47.jpeg
  • MDesignMDesign Member Posts: 1,286 PRO
    edited July 2025
    Essentially you don’t. measure the line and subtract off 5mm and enter that in situation 1
    if you want it to be dynamic you would have to create at a few variables to enter a formula instead of a static value
