Cutting a section of an assembly to send to supplier
CAD3D_designCAD3D_design Member Posts: 9 PRO
hi all,
I want to send a supplier a section of a 3D assembly rather than the whole model. In Solidworks I typically do this using the assembly cut tool to cut multiple parts at the same time, then export in STEP format and delete the cut.
Is there an easy way to do this in Onshape?
thanks,
Pete
