Need a rib tutorial that actually works.
spencer_arnold
Member Posts: 11 ✭
Keep trying rib tutorials but none actually work. I select the plane same direction as the rib (see rib1), but there are no snap icons and the lines I do draw are well offset from the planes (see rib2 and rib3).
There has got to be a pre-requisite for the snap icons but none of the tutorial match it. What is missing here?
What is missing here? Spencer
@spencer_arnold
You need to use a sketch plane that matches your rib, of course, at least for your first rib. Then:
OK Thanks martin, that has answered my question on the pre-requisites.
Learning the mate connector in sketch mode can save making a new plane in the feature list by picking up a mid point. The mate connector is fully adjustable as needed.
Then continue as Martin noted.
https://cad.onshape.com/documents/105b04ed73945e85546e3fed/w/c54027e5d2700d0a69cbc2ae/e/aabe6f5deba270506b98ca3f
