Need a rib tutorial that actually works.
spencer_arnoldspencer_arnold Member Posts: 11
Keep trying rib tutorials but none actually work. I select the plane same direction as the rib (see rib1), but there are no snap icons and the lines I do draw are well offset from the planes (see rib2 and rib3).
There has got to be a pre-requisite for the snap icons but none of the tutorial match it. What is missing here?
What is missing here? Spencer
