Adding part to assembly via API
johannes_3000johannes_3000 Member Posts: 9
I am trying to add an assembly into another assembly via API. Trying out the REST call in glassworks i get an error saying i am using a microversion even though i am using a version:
This is the document I am pasting:
https://cad.onshape.com/documents/ba1fece8e8480bb1fa5c2089/v/6d2dabf62ee2588360f457fe/e/ab51836df1310fcc7922ea92
Error: response status is 400
Response body
Download
{  "message": "Microversions may not be used with linked document references",  "status": 400,  "code": 9999,  "moreInfoUrl": ""}
I also don't understand how that API call should work since it only specifies one part/assembly. Is it the target or the payload?
I also have tried the same in python wihtout success but thats a different topic. Lets get this glassworks example working first. Any pointers welcome, thank you!
  • Caden_ArmstrongCaden_Armstrong Member Posts: 343 PRO
    It would help to know the body you are using for your request. Your body is probably the problem.
    I know you can do it with just:
    documentId
    versionId
    elementId
    isWholePartStudio=false
    isAssembly=true
    configuration={config if applicable}
    You might be adding extra parameters that you don't need to add. The API can be a bit fussy if you include unnecessary parameters
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • johannes_3000johannes_3000 Member Posts: 9
    Ok, I didn't fill in anything besides the autofill option in the glassworks. Now it works with the additional payload parameters.
    Not able to get the inserted assembly to appear at a different location though - I am using:
    "documentId": "5ec100e212a5fab5ff355415",
    "elementId": "883aca11d7be9449d88a79a6",
    "includePartTypes": [
    "PARTS"
    "transform" : [
    1, 0, 0, 0,
    0, 0, -1, 0,
    0, 1, 0, 1,
    0, 0, 0, 1
    "isAssembly": true,
    "versionId": "5aa8b24aaac7e7881e21e1f2"
    Any hints, should this work?
    Thanks @Caden_Armstrong for the response, that helped. Just realizing that for a transform I probably have to use the occurrencetransforms.
    Can you advise on how to use it, what do i need from the payload and how do i determine path?
    "isRelative": true,
    "occurrences": [
    "fullPathAsString": "string",
    "headInstanceId": "string",
    "internalOccurrence": true,
    "occurrenceWithoutHead": "string",
    "occurrenceWithoutTail": "string",
    "parent": "string",
    "path": [
    "string"
    "rootOccurrence": true,
    "tailInstanceId": "string"
    "transform": [
    you're better off using "transformedinstances", inserted with a specific transform.
    If you insert and then transform it requires a bunch of extra API calls, where as the transformedinstances endpoint lets you do all your insertions/transforms in a single call. With Onshape's API limits that can make a big difference to your usage.
    thanks!
