New Custom Feature: Segmented Pipe
joshtargojoshtargo Member Posts: 472 EDU
A Featurescript to create a one or more pipes (cylinder or hollow tubes) between two locations (point, MC, arc, circle). The pipe can be split into segments with a remainder piece representing a cut section. Various options are available during creation.
I created this to help with HVAC ductwork.
Let me know if you have issues or improvement requests.
https://cad.onshape.com/documents/b08acb3b79f42f8e5008740a/w/d1a55166098ecdeb1b2675e0/e/5f0750551e96fa080dcb00a3
  • amandeep_singh296amandeep_singh296 Member Posts: 3
    Hi,
    It says: "Document failed to load for workspace. Resource does not exist, or you do not have permission to access it." when I tried opening the url in your post
  • joshtargojoshtargo Member Posts: 472 EDU
    edited July 2025
    sorry, forgot to make public:
