How to rotate
I've created two parts and want to assemble them but when I open up assembly and add parts to assemble l know l can fix one part but the other part l need to be able to rotate with out both moving the same time and l need to be able to change angle of parts to position properly. Is all this possible and how to do .l watched a lot of videos and can't seem to figure it out.
I would highly recommend the Onshape Learning Center
https://cad.onshape.com/help/Content/triad.htm
