Internal cavities when slicing for 3d print.
Hello.
I have a problem where the slicer interprets internal cavities as cavities, but I want them to have infill. (Creality print slicer)
Does anyone know what I could do to fix this in OnShape? Is there some way to make it solid?
Link to model:
jonathanb_sydney Member Posts: 27 PRO
As the others have pointed out this is a slicer question. you need a modifier body which you can set to 100% infill or someother set of settings. plenty of good resources on the internet. such as
another option is you can make your own modifier body that is more complex than a simple box cylinder which is all you can do in the slicer natively. If you import both bodies into the slicer, and set the second one to be a modifier body. Then (only) where it overlaps with the first body, it will apply the custom settings.
I think that's a slicer question. There is usually am option on these things to select areas you don't want supports.
there is no cavity in your model. I think you have to set the infill in your slicer.
Thank you!
