Elevation for cold frame
ProApeProApe Member Posts: 198 ✭✭
edited July 27 in Using Onshape
Hello,
I would like to create a possibility for cold frames formed by inox profiles whose upper edge is bent in such a way that (theoretically) no snails can get into the cold frame, and which are covered with a wire mesh to prevent other animals such as cats from making themselves comfortable or making their emergency calls in it, to attach the mesh higher, as various plants abut against it.
For this purpose I measured a profile, 3d printed it first as a sample, and adjusted it to fit, then added a structure with 2 possibilities at different heights to put iron bars on it to put the grids on.
But since I want to CNC-mill the parts from wood, I reinforced the parts.
I'm stuck with an extrusion that won't work.
What am I doing wrong?
Kind regards
ProApe
  • ProApeProApe Member Posts: 198 ✭✭
    sorry, posted too quickly once more; better check everything carefully first.
    I noticed that the extrusion was set to Thin instead of Solid.
    I wanted to delete the whole post, but that doesn't seem to be possible.
    sorry
