Derived via FS adds mate connectors that don't exist when derived directly as feature
vanowm
Member Posts: 135 ✭✭
I'm trying to understand the reason and how to avoid deriving mate connectors via FS.
I have simple part studio with a cube and hole:
There is no mate connectors exist.
However, when derive this part via FS, it also adds mate connector for the hole:
Why this happening and how to avoid these mate connectors?
Thank you!
P.S.
My FS:
FeatureScript 2716;
import(path : "onshape/std/common.fs", version : "2716.0");
base::import(path : "8da0e6444c771cd3d2fd6b25", version : "7ec130d1aa4cd83526a447a8");
annotation { "Feature Type Name" : "Derived FS" }
export const example = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Hole size"}
isLength(definition.hole_size, {(millimeter) : [0.01, 3, 1e5]} as LengthBoundSpec);
var instantiator = newInstantiator(id + "track");
// Add it to your Part Studio
var query = addInstance(instantiator, base::build ,{
"configuration": {
"hole_size": definition.hole_size
instantiate(context, instantiator);
If you look at the definition for addInstance there is an option to provide a query for what will be included in the instantiation - "partQuery"
By default it brings in everything, but you can limit it with a query like qAllSolidBodies()
Thank you!
This works:
"configuration": {
}, "partQuery" : qAllSolidBodies()
https://greasyfork.org/en/scripts/565664-onshape-auto-login
