face of extrusion won't take fillet
alan_stuckyalan_stucky Member Posts: 5
The top surface of this won't take any fillet of any size. I can't seem to figure out why. Even very small fillets of .01 inches won't work, there shouldn't be any overlapping, even at that size.
https://cad.onshape.com/documents/31eb56ebfc05442f4756bff6/w/ad8e7e1eb41e373f382996bc/e/e3965fdf415e9bfa0c47c79e?renderMode=0&uiState=688a81a365539c40a5e68acb
  • EvanReeseEvanReese Member, Mentor Posts: 2,862 PRO
    Something's off in this area. If you cut it away it works. The edge on the left looks especially sketchy to me the way it kinda disappears.
  • alan_stuckyalan_stucky Member Posts: 5
    That's helpful. How did you cut it away? there are several ways I could do that and some of them seem to mess with some other geometry, especially on the face blend.
    Oh i meant I blasted a big hole and moved it around to diagnose the failure by seeing when the fillet feature worked again. It's kind of similar to the technique I used in this video to find an error. To actually fix it, I'd revisit how it was made in the first place and do it a cleaner way. I didn't look at how it was made. If you get stumped bump the thread again.
    Thanks!
