Will we ever be able to getProperties() during regen?
EvanReeseEvanReese Member, Mentor Posts: 2,604 PRO
Might be a questions for @ilya_baran or @lana.
I know it's a current limitation that getProperty() only works in things after feature regeneration like Custom Tables and apparently Editing Logic. I believe it's regen order that means the properties "don't exist" until after the features regen. Do I have that right? In any case, my question is will this ever change? The more teams I work with the clearer it is that data wrangling is as big or a bigger challenge than just modeling things, and there are a lot of data challenges that could be solved by access to part properties during feature regen.
In a similar vein, is it on the road map to be able to set previously un-set properties without having to "Reset all"? It would certainly make for a more streamlined and intuitive experience.
Are these too architecturally fundamental to hope for these changes?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,245 image
    Makes sense. The changes involved would be pretty fundamental, but we've been kicking around some ideas that could change (among other things) how this works. Now, if something comes of it, it's still years out.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 334 PRO
    +1 to this being a bit of pain.
    How do you handle the corner cases like changing a property in a versioned part studio? Versioned documents shouldn't change, but changing a property would have to trigger regen?
    setproperty should take in a parameter for "override user set property" to allow us to always set a property - even if the user manually changed it at some point. One of the benefits of FeatureScript is to enforce standards. But allowing a user to supersede that standards enforcement limits its value.
    I know that a user could change it, and regen will have to happen for it to be applied again, but thats better than what we currently have.
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • MichaelPascoeMichaelPascoe Member Posts: 2,604 PRO
    +1
  • EvanReeseEvanReese Member, Mentor Posts: 2,604 PRO
    Thanks, Ilya. I assumed it was fairly fundamental, but I would love to see something like this on the roadmap. No clue if the scale of the challenge is similar, but it makes me remember how variables in sketch patterns weren't possible for so long because of some non-trivial challenges, and it got done eventually (and I use it a lot now). I'd love to be part of an EVP for it whenever that is.
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 164 PRO
    +1
    chadstoltzfus@premiercb.com
