Extrude along a angled surface
hamza_ali723hamza_ali723 Member Posts: 4 EDU
Hi,
I want to extrude a sketch along an angled surface. How can I do it?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 761 ✭✭✭
    Select the edge face as the sketch plane. - Scotty
  • MDesignMDesign Member Posts: 1,329 PRO
    you can select faces or edges or even use mate connectors to define an extrude direction.
  • hamza_ali723hamza_ali723 Member Posts: 4 EDU
    Here is another angle.
    Can you explain how I can extrude along these faces now?
    Extrude what along what faces? Probably the same process, but not very clear what your trying to accomplish
