Invalid Normal Until a More-Distant Point is Used
What is going on here?
I have 3 points that are co-linear (start, mid, end) that produce an invalid normal when used with this code. If I make a 4th co-linear point that is farther away, it works fine.
It seems that when too close together it is for some reason "close to parallel". Why does OnShape let this sort of inconsistency occur?
var scaleLength = 24.75*inch;
var stringHeightAtFirstHarmonic = 1*millimeter;
const start_point is Vector = vector( 0*inch, scaleLength / 2, 0*inch );
const mid_point is Vector = vector( 0*inch, 0*inch, -stringHeightAtFirstHarmonic );
const end_point is Vector = vector( 0*inch, -scaleLength / 2, -2*stringHeightAtFirstHarmonic);
// For some reason OnShape produces a 0 normal if mid_point is used in place of other_point.
const other_point is Vector = vector( 0*inch, -scaleLength, -4*stringHeightAtFirstHarmonic);
const origin = mid_point;
const normal = cross( start_point - end_point, start_point - other_point );
var neckReliefPlane = plane( origin, normal );
// create fret relief sketch on side plane
definition.neckReliefSketch = newSketchOnPlane(context, id + "neckReliefSketch", {
    "Name" : "Neck Relief Sketch",
    "sketchPlane" : neckReliefPlane
  • EvanReeseEvanReese Member, Mentor Posts: 2,826 PRO
    I'll kinda sidestep your question a bit to get at your goals. The cross product of parallel vectors should be a zero vector with no direction, so the case where it works seems like the odd one out. Might be a floating point precision thing making the second case just off enough to get a result from cross()? In any case, if you just need any perpendicular vector try perpendicularVector() instead of cross(). If you need to know for sure which direction that normal will go, then you could align it to something else known.
  • AsherAtSignalDesignAsherAtSignalDesign Member Posts: 34 PRO
    I think the problem is simply that it can't figure it out if they're on the same line? But why does it work then with another point on the same line?
  • _anton_anton Member, Onshape Employees Posts: 515 image
    If the points are indeed collinear, why do you expect a cross product of two parallel vectors to produce a valid normal?
  • amora_salimamora_salim Member Posts: 4
    edited August 2025
    @Granny Game That’s a fascinating observation — especially about how mid_point seems to break the normal.
    I’m curious, could this be due to floating point precision issues in the cross() function when vectors become nearly co-linear?
    Have you tried introducing a small epsilon offset in the Z or X direction to test how sensitive normal is in this case?
    Also, is there any documentation on how Onshape handles degenerate or near-degenerate vector calculations in FeatureScript?
    (I should also remark that other_point isn't collinear with the others, which is why it produces a nonzero cross product.)
    As for vector calculations, we don't do anything special; that's on the FS author. If three points are on the same line, you can't expect them to define a plane, so you rightly get a zero-length normal. Floating-point artifacts can give an illusion of a valid result, so you can use parallelVectors to test for invalid inputs, which does a tolerant comparison. You can read the math here: https://cad.onshape.com/documents/12312312345abcabcabcdeff/v/b61084c68a86eaf27d3b94ce/e/b81f3a02f1e34b7dab9d239c
