export problem!
minh_bui528
Member Posts: 7 ✭
There are some problems when exporting the STEP file. When I export this solid part as a STEP file and then import it into SolidWorks, some surface parts appear broken or corrupted. I'm not sure why this happens. If anyone knows how to fix this issue, please help. Thank you!
Use Parasolid for Solidworks. It's the native kernel of both programs so there should be no translation issues.
@S1mon thanks :*
