Learning Center - Mark lesson as completed
I am using learning center and enroling in courses, learning paths and lessons.
Usually when I complete these they are moved from the "My Learning" tab into the "Completed" tab. But I recently started the lesson "Oneshape Assembly Basics" and completed it, and it hasnt moved there.
This is not a problem with lessons themselves - as I have a lesson in the "Completed" tab, but just this one. How can I move it to the "Completed" tab ?
Did you complete the question and answer part at the end of the lesson? Usually a query about part mass or something. Go back to the lesson and if not done it will still be at that stage.
There is no question at the end, or at least I dont find it…
Isn't the verification process at the end exclusive to courses (not lessons) ? I am not sure, that is the only difference I noticed between courses and lessons.
The confirmation used to be included after each lesson. At the end of the course if I remember correctly there may be some other questions or survey. If all is not completed then the course is not complete and no certificate. If you keep saying next it should move on to another course.
