How do I change how onshape names my sheet metal flat patterns when I export them?
example:
I export a flat pattern to DXF to nest and cut on a laser table.
the file is exported as the project name, great, and then the files show as "project name - Flat Pattern of Part name"
I would like the files to just be named "Part name"
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 57 PRO
    Configure this in Export Rules, either under your User Account Settings or Company Account Settings (if you're on Pro or Enterprise)
    Good tech tip here: https://www.onshape.com/en/resource-center/tech-tips/tech-tip-how-to-set-up-export-rules-in-onshape
  • dustin_144dustin_144 Member Posts: 2 PRO
    Ran into something similar, easiest way is to write a shell script to remove the "flat pattern" ask chat gpt if you need help.
    Here is a close example
    #!/bin/bash
    Removes "Flat pattern" (and extra spaces) from DXF filenames in your export folderChange this to your export folder path:
    FOLDER="$HOME/Downloads/OnshapeExports"
    cd "$FOLDER" || exit
    Loop through matching files and rename them
    for file in "Flat pattern"; do
    newname="${file//Flat pattern/}"
    newname="${newname// / }" # remove double spaces if any
    mv "$file" "$newname"
    echo "Renamed: $file → $newname"
    done
    echo " Done cleaning DXF filenames."
