Improvements to Onshape - August 7th, 2025
2»
  • EvanReese
    EvanReese Member, Mentor Posts: 3,090 PRO
    edited August 2025
    I think it only works with list inputs as the driver of the condition. I'd love to see more flexibility though with custom expressions that return a boolean..
  • _anton
    _anton Member, Onshape Employees Posts: 554 image
    ^ We disallow setting conditions based on continuous parameters because floating-point math quickly gets you into gross situations.
  • EvanReese
    sounds gruesome. Would still love to have a way to do it some day, perhaps with a way to loosen the tolerance a bit in the condition setting.
  • Jason_S
    Jason_S Moderator, Onshape Employees, Developers Posts: 225 image
    We have the "always show" option in the works. There was value in getting this out rather than holding for that.
    Enums/lists for now. Other parameter types coming later.
    Support & QA
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,956 PRO
    edited August 2025
    Ok 😎👍️, good to know, I'm not too crazy then.
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,121 image
    @MichaelPascoe you can't configure visibility based on a variable, though it would be nice.
  • klaus_krämer
    klaus_krämer Member Posts: 96 ✭✭✭
    @Jason_S "We have the "always show" option in the works. There was value in getting this out rather than holding for that."
    Very much appreciated - Thanks! 😊
  • Daniel_Sterling
    Daniel_Sterling Member Posts: 7 PRO
    Thanks for the Units update. Now can you make it so that if i need to change a document from Imperial to Metric units, there is a "one click" option to do so? Changing from ANSI to ISO or just Imperial to Metric so that all types are changed together is helpful rather than having to change each one individually.
  • Nick_Holzem
    Nick_Holzem Member Posts: 250 PRO
    Are the shared document links now removed from the new support tickets process? Having the reference link automatically added with hyperlink capability was very handy when reviewing support tickets. It shows up in the referrer line in the additional information but only as a cut and paste link. The hyperlink is much better, please add this back.
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,020 image
    @Nick_Holzem Honestly the links were for added initially for us (support), which I temp fixed on our end but yes it was an oversight on my part added the additional information into a code block, which our ticketing system does not recognize hyperlinks in like some other systems.
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • christopher_dziuba
    christopher_dziuba Member Posts: 124 ✭✭✭
    Incredible! Absolutely fantastic!
  • Nick_Holzem
    @lougallo looking forward to them being back! Thank you.
    S1mon Member Posts: 4,609 PRO
    It's about that time again…
    Hoping that we get some nice surprises before the long weekend (at least here in the US).
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,160 PRO
    My wishlist for the month is more NURBS utilities. I'm deep in whitepaper territory and I feel like I'm one kernel function exposure away from some really cool tools.
  • robert_stiles
    robert_stiles Member Posts: 201 PRO
    One simple wish, every three weeks…. Supress features by expression.
