Extrude along a angled surface
hamza_ali723
Member Posts: 4 ✭
Select the edge face as the sketch plane. - Scotty
you can select faces or edges or even use mate connectors to define an extrude direction.
Here is another angle.
Can you explain how I can extrude along these faces now?
Extrude what along what faces? Probably the same process, but not very clear what your trying to accomplish
