screw stop point
michael_valberg
Member Posts: 7 ✭
in Drawings
whats the best way to make screw realistic?
or stop point or what its called?
this way to short m8x45 screws through the m8 hole wich is 80mm deep.
i want the screw to stop at its shoulder.
https://cad.onshape.com/documents/0d5482df03fd062ac886683f/w/a5cbe85d3e58754944f0e74c/e/f04d45af908faef014acee89?renderMode=0&uiState=689f8ad4f7d1256ee87f2c8a
Hey Michael. That's some heavy-duty model. What's it's intended purpose?
If I understand your post correctly. You want the underside face of a screw head to mate to the bottom face of a counter bore. I see you've already got a mate connector in the correct position on a socket head cap screw. It should be no problem to place a mate connector on the face of the bottom of the counterbore. Are you having a problem in selecting that face?
After taking another look at your document, I see that Fastened 34 has done just that. I don't understand what you need help with. - Scotty
