can someone tell me why this loft doesn't work?
1
Matt_Shields Member, Onshape Employees Posts: 768 PRO
might need to check "Connections." Also, maybe use New, not Add.
MDesign Member Posts: 1,139 PRO
while not required it might help, when possible, to try making sure your profile sketches have the same number of connected points/segments… and the connecting points located in a similar proportionate fashion.
that seems to help but still doesn’t work all the time just messed around with some of the connections
