Mapping faces from a plane onto another plane
noé_perard_gayot
Member Posts: 4 ✭
I'm trying to make a function that "wraps" a plane onto a plane or onto a curved surface. It works for curved surfaces :
const targetWrap is WrapSurface = makeWrapSurface(context, definition.target);
const sketchPlane is Plane = evOwnerSketchPlane(context, { "entity" : definition.faces });
var result is Query = qNothing();
if (!isWrapPlane(context, targetWrap))
opWrap(context, id + "map", {
"wrapType" : WrapType.TRIM,
"entities" : definition.faces,
"source" : makeWrapPlane(sketchPlane),
"destination" : targetWrap
result = qCreatedBy(id + "map", EntityType.BODY);
else
const targetPlane is Plane = evPlane(context, { "face" : definition.target });
const moveFaces is Query = qEntityFilter(definition.faces, EntityType.FACE);
const planemap is Transform = transform(sketchPlane, targetPlane);
debug(context, moveFaces, DebugColor.RED);
opMoveFace(context, id + "map", {
"moveFaces" : moveFaces,
"transform" : planemap,
result = qCreatedBy(id + "map");
The result when extruding the query `result` is somewhat strange (moved from a plane to an offset plane) .
I'm sure there's an obvious solution, but for now I don't have a clue.
If your goal is to transform the letters from the cSys of sketchPlane to the cSys of targetPlane, then moveFace() isn't probably what you want. Look at opTransform().
