DXF / DWG EXPORT UNITS
Hi, as of the last update, you can now override the default units when exporting a DXF or DWG flat pattern in sheet metal. The default is Meter, can you change this default setting? We use Millimeters, and didn't spot this change, we just caught it in time before the laser cut some very small parts 😁.
Many Thanks.
Craig
Same issue.
Please help to resolve.
@onshape
We would like to have inch since all our other default settings are set to imperial.
Twitter: @BryanLAGdesign
Same issue!
Same issue here!
Same issue here
I have had to re-export four complete jobs since this change. It has cost me many hours of work.
I would like to have this settable as your own default also.
Same. This is getting really annoying. Who TF designs in meters?
