Unable to apply transformation?
Hi everyone, I’ve done several of the beginner course at the OnShape learning center so I thought I had the basics down. I was trying to rotate a rectangle but it just isn’t working so I went more basic and tried to rotate a line, yet still nothing. I’ve read several posts on here and even asked chat GPT yet I was still unsuccessful. Am I missing something obvious? I’m using an iPad Pro if that makes a difference?
Here’s what I’m doing (here’s a link to a screen recording of what I describe below) :
I start a fresh document
Create a new sketch on the top plane
Confirm the sketch
Edit the sketch
Select transform
Remove any constraints
Rotate the line
Confirm the transformation
nothing happens
So I select edit again
Select transform
Rotate
nothing
  • eric_pestyeric_pesty Member Posts: 2,292 PRO
    You have to "accept" the transform before you exit the sketch, you were just looking at the preview of the transform
  • arthur_moore347arthur_moore347 Member Posts: 4
    Yup I realized shortly after posting this that tapping the green check mark doesn’t work on iPad like it does on a standard browser, I have to tap in an empty area to apply the transformation then the green check mark just exits the edit mode on the sketch. Thanks for your help!
