Looking for a method to create swept volume of a moving assembly
martin_kopplowmartin_kopplow Member Posts: 846 PRO
edited August 19 in Using Onshape
I have an assembly that moves, and I need to create a volume of all space the moving parts occupy along the whole range of movement. The move is of course not linear, nor rotational, but a hybrid of both. It is controlled by two non-parrallel slots sliding on two pins.
I can't imagine this is the first time such is required. Is there possibly a tool existing that can do that, and which I am not aware of?
Here's a simplified sample. The grey part moves. The original assembly has way more parts and different dimensions, though:
https://cad.onshape.com/documents/32520a0e2a226330185ad2c5/w/3d62121d28258c15f9d2a76a/e/3a4051b822ff1f8c201401ce?renderMode=0&uiState=68a4e19d8364e24e3ffe8bbb
What might be the best way to create such volume?
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 175 PRO
    You need a body sweep feature, which hasn't yet been fully implemented by anyone that I've seen so far. CADSharp has a couple of features that are partly what you're asking for but not quite all there.
  • S1monS1mon Member Posts: 3,454 PRO
    edited August 20
    Body sweep in Solidworks exists, but it doesn't create very clean results.
    Depending on what you're looking to accomplish, there is a FeatureScript which will trace a path for a linkage. You might be able to do that for the furthest out edge on the moving part.
    I don't fully know how to optimize this, but I think you can solve the 2D problem with Curve Generator.
    @S1mon ooh that linkage script hasn't made it into my collection yet. I might be able to extend that into a better body sweep implementation. Got a link?
    edited August 20
    @Derek_Van_Allen_BD the text should be linked above, but…
    https://cad.onshape.com/documents/d8aab1e0e7ae10038a6830e0/w/9dfdd631d025960813b8f2df/e/621b5be97d38074a1f1546e5
  • wayne_sauderwayne_sauder Member, csevp Posts: 611 PRO
    @S1mon
    Looks like it is an enterprise link.
    edited August 20
    @wayne_sauder
    Thanks. I missed that. Should be fixed now. I wish the Forum would warn us when we make that mistake.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 162
    Hey @martin_kopplow,
    Have a look if you can do it with this custom feature from Neil: https://cad.onshape.com/documents/408b473b45dbdc2c1ea6f956/w/1d3090ad84ff6ff900bec08c/e/397b5c9a4764bb333502a3e4
