Looking for a method to create swept volume of a moving assembly
I have an assembly that moves, and I need to create a volume of all space the moving parts occupy along the whole range of movement. The move is of course not linear, nor rotational, but a hybrid of both. It is controlled by two non-parrallel slots sliding on two pins.
I can't imagine this is the first time such is required. Is there possibly a tool existing that can do that, and which I am not aware of?
Here's a simplified sample. The grey part moves. The original assembly has way more parts and different dimensions, though:
https://cad.onshape.com/documents/32520a0e2a226330185ad2c5/w/3d62121d28258c15f9d2a76a/e/3a4051b822ff1f8c201401ce?renderMode=0&uiState=68a4e19d8364e24e3ffe8bbb
What might be the best way to create such volume?
You need a body sweep feature, which hasn't yet been fully implemented by anyone that I've seen so far. CADSharp has a couple of features that are partly what you're asking for but not quite all there.
Body sweep in Solidworks exists, but it doesn't create very clean results.
Depending on what you're looking to accomplish, there is a FeatureScript which will trace a path for a linkage. You might be able to do that for the furthest out edge on the moving part.
I don't fully know how to optimize this, but I think you can solve the 2D problem with Curve Generator.
@S1mon ooh that linkage script hasn't made it into my collection yet. I might be able to extend that into a better body sweep implementation. Got a link?
@Derek_Van_Allen_BD the text should be linked above, but…
https://cad.onshape.com/documents/d8aab1e0e7ae10038a6830e0/w/9dfdd631d025960813b8f2df/e/621b5be97d38074a1f1546e5
@S1mon
Looks like it is an enterprise link.
@wayne_sauder
Thanks. I missed that. Should be fixed now. I wish the Forum would warn us when we make that mistake.
Hey @martin_kopplow,
Have a look if you can do it with this custom feature from Neil: https://cad.onshape.com/documents/408b473b45dbdc2c1ea6f956/w/1d3090ad84ff6ff900bec08c/e/397b5c9a4764bb333502a3e4
