Hollow sections don't simulate?
Richard_InvRichard_Inv Member Posts: 39 PRO
edited August 2025 in Simulation
So I have a simple rectangular frame, attached to two fixed pins.
It simulates fine when the frame is solid, takes about 1 minute
But when I make the frame hollow (about 2mm thick), it just will not simulate. Just spins the loading wheel
Setup pictured below, if anyone has any ideas?
