Create and edit an object using a DXF file
Zipfel_TomZipfel_Tom Member Posts: 5
Hello everyone,
I wanted to create a part using a DXF file, center it in an object, and then remove it. Now it always displays an error and only the part that has not been centered can be removed. What am I doing wrong and are there any better solutions?
https://cad.onshape.com/documents/d18bf1e09f80281cfe068b8d/w/ba2aa47560fdcb8cb4c5856f/e/122f68a742aa054b8397866d
  • glen_dewsburyglen_dewsbury Member Posts: 1,145 PRO
    Take a look at this sample and let me know if it's what you're looking for. If yes then I'll go through and explanation of how I got there.
    https://cad.onshape.com/documents/c4c2736f0f28427d2e940c43/w/829e20ef954014f18112bdc0/e/fa9eb843384482ad9bc5dd7d
    Should be able to open now.
  • Zipfel_TomZipfel_Tom Member Posts: 5
    Thank you very much for your efforts.
    Unfortunately, I cannot open the document.
    From what I can see in the photo, it should be exactly as I imagined it.
    Thank you very much.
    Looks like I took too many steps and ended up messing everything up.
    Thanks again for your support. I would probably have spent many more hours getting annoyed and making everything even worse.
