WebGL problem with Firefox and Google ANGLE
matt_insley
Member Posts: 2 ✭
FYI, ran into a recent issue where onshape's compatibility checker said I had webgl disabled (I did not), with a supported GPU and recent(ish) drivers.
The issue seems to be some Gl compatibility layer called Google ANGLE.
Steps taken:
1. https://cad.onshape.com/check showed webgl not enabled, whole section red
2. I checked "about:config" to see that webgl was in fact enabled (webgl.disabled=false)
3. Then checked "about:support" to reveal that the renderer was "Google Inc. (NVIDIA) -- ANGLE (NVIDIA, NVIDIA GeForce RTX 3090 Direct3D11 vs_5_0 ps_5_0, D3D11-32.0.15.6094)"
4. Suspicious………. Went back into "about:config" and turned off ANGLE (webgl.disable-angle=true)
5. Now everything is working correctly :)
Firefox ver: 138.0.1
GPU model: Nvidia RTX 3090
GPU driver ver: 560.94
OS ver: Windows 10 v19045.5737
I just followed step #4 and that fixed the problem for me. I'm also on Firefox, but I'm using an Intel Arc B580 card (though I do have an inactive NVIDIA GeForce RTX 2070 in my system).
