Removing a taper section from the edge of an extrusion
peter_paton
Member Posts: 43 ✭✭
Hi, I am trying to remove a tapered section from an edge as per the example and can't work out how to do it. Can someone shed some light please?
Need more context. No example given.
Hey Peter. Not clear on what result you're looking for. I just took a guess. Is the image what that result is? - Scotty
Hi Robert, yes that is what I am looking to do.
Ok Peter. Take a look at this copy of your document to see the method used. Come back with any questions you may have. - Scotty
