How to loft a surface from 1 profile contours to 2 profiles in the next plane?
Zhi_Ern_TeohZhi_Ern_Teoh Member Posts: 2
  • S1monS1mon Member Posts: 3,746 PRO
    Short answer - you can't.
    The Loft feature doesn't work with more than one profile, and it definitely can't loft from one to two profiles. You'll need to model this transition with other - most likely - surfacing techniques.
