(CAM Studio) Mach4 post processor for Mach3?
Cedric_EveleighCedric_Eveleigh Member, OS Professional, csevp Posts: 73 PRO
This might be a silly question. Does gcode from the Mach4 post processor in Onshape work with Mach3? I have a cheap 3-axis CNC router that runs Mach3.
  • nico_b681nico_b681 Member Posts: 2
    Hi, I had the same question and didn't find an answer, so I just tried it. So far it seems the gcode works as expected with Mach3, using the Mach4 post processor in Onshape.
    Good milling!
