New Custom Feature: Bi-Rail Surface
joshtargojoshtargo Member Posts: 440 EDU
edited September 6 in FeatureScript
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 343
    Nice! I've always liked your curve manipulation feature that you've extended to do this. It is the most obvious use case for it (I think) so makes sense to wrap it into one. I'll experiment with it some more…
  • S1monS1mon Member Posts: 3,539 PRO
    Excited to play with this.
  • joshtargojoshtargo Member Posts: 440 EDU
    this is basically why i wanted to do it in the first place, not sure why i never added this in before.
    Works as mono-rail now as well.
  • martin_kopplowmartin_kopplow Member Posts: 903 PRO
    Interesting. I can see some cases for a first surface, though I find it hard to control when other surfaces are already existing, for rail tangency cannot be controlled, and isn't kept when initially existing in the profile curve.
    https://cad.onshape.com/documents/f2498ef6f1a14692e4bcdcc5/w/a11914a6fbcaa02473d9ee70/e/c16db0a254f1ba5814211f50?renderMode=0&uiState=68bd4436ed8291a8c0a34092
    if you have two surfaces, you can just bled between them. Birail and monorail are more intended to be used for creating initial slabs when you have very little to work with, or maybe just scan data
