Revision Management for BOM
I have run into a slight inconvenience that I think most people also would run into. I am mainly in the aerospace sector and leaving cells empty is seen as unprofessional and frowned upon. Right now I only have necessary pieces as revision controlled. This makes my Assembly Drawing BOM have only a few sections in revision populated. Is there a way to make it Auto populate with a "N/A" or "-" for parts that are not revision controlled?
  • S1monS1mon Member Posts: 3,568 PRO
    There's no automatic built in way to do this, but you can select "Not revision managed" in the properties and fill in the revision with "N/A" or "-". If you want that to be an automatic revision when "Not revision managed" is turned on, it sounds like a good improvement request.
