Entering Variable name on Sketch Dimension changes view
henry_feldmanhenry_feldman Member Posts: 135 EDU
So on my Mac (tested on multiple Macs) in Safari or Chrome, if you create a sketch shape (for example circle but any will do) and hit return to end the shape and show the dimension data field, if you try to enter a variable name it changes the view (i.e. the # key shortcut is activated rather than the character in the variable name). Am I crazy or are you not supposed to be able to use a variable at that point? I assume something is trapping the "#" key, as it is instant. If you just hit return to accept the shown dimension, then go back and use the Dimension tool, it all works as expected… See image below as soon as I type # the view changes to Left. Note if I had typed a number it would be typing in that field. This is 100% reproducible.
