variable in part properties
Bernhard_HirtBernhard_Hirt Member Posts: 2 PRO
Hi,
is there any way to get the variable in the part configuration without typing it in manually?
I know that I could do a list configuration with fixed lenghts and then I can configure the properties for every item in the list. But I would like to this automaticaly.
In this case I want to have the length of different wiring ducts in the comments.
thanks.
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 43
    With a configuration variable, you'll need to use a Custom Feature to assign the Property with an expression.
    See the Part Name custom feature, call this, chose expression, and insert the variable. May need to do some rounding/scaling to deal with the default unit conversions, but you can easily tag the variable in the Part name or number!
    https://bedfordstatics.onshape.com/documents/cff5249641e260dddc6588dc/w/f11992258668fd8ed8744408/e/0fe4c3e97c01eb56d1722272 - link share to example
  • MichaelPascoeMichaelPascoe Member Posts: 2,536 PRO
    I'll echo what Kevin said.
    Within a feature, you can turn most inputs into an expression by right clicking it → convert to expression. This will let you use variables and equations in that input, it will even let you use inline FeatureScript. For example if you had name variables: #prefix ~ "_" ~ #size ~ "_Config"
    Evan's Part Name feature is good. However, if you want to be able to set any property, not just the name,
    you could use the Property Attribute thumbnail.png Property / Attribute feature.
    If you want to quickly turn lengths into a readable format for part names or descriptions, then I recommend the Variable to string thumbnail.png Variable to String feature.
